1995 Acura NSX
Locked
Emdoller
1995 Acura NSX
Post by Emdoller »
AC blowing warm air
It's been a while since I used my AC but I was blowing hot air.
I've fixed many AC systems on old Chevrolet cars that used R12 and understand the fundamentals. My NSX is a 95 and has r134.
My questions:
1) should I simply try adding more r134 and see what happens while monitoring low side pressure?
2) do I need to jump the low pressure switch to add it?
3) should I simply follow the standard r134 temp vs pressure curves?
Or
4) should I pump the system down and start fresh adding the proper r134 by weight?
Ed
Re: 1995 Acura NSX
Recover & charge by weight. Then you can evaluate system performance.
It probably has a leak I would add dye when recharging, and inspect everything after running the system for an hour or more.
Edited to add:
That system is tiny. Really easy to overcharge, and "topping up" can go from not enough to too much pretty quick. Use a scale.
Re: 1995 Acura NSX
bohica2xo wrote:Recover & charge by weight. Then you can evaluate system performance.
Proper advice, I'll second this method.
Emdoller
Re: 1995 Acura NSX
Post by Emdoller »
Thanks!! I'll pull a vacuum this weekend and see if it holds. Then if it does, I'll add the recommended amount of r134 using a scale.
I'll keep you posted.
Thanks!
Ed
Dougflas
Re: 1995 Acura NSX
Post by Dougflas »
System can hold a vacuum and still have a leak. Dye is your friend.
Emdoller
Re: 1995 Acura NSX
Post by Emdoller »
Got it. Will add dye as well.
Ed
Locked
