cool AC only when idling, warms up when revving
httran5
Post by httran5 »
2016 Nissan Rogue S AWD (salvaged). I've had it since February of this year and I just started having problems. I'm going crazy trying to search the web for a solution! The A/C blows cold only at idle but warms up when I revv/accelerate.
At 105°F and idling, it's blowing cold and normal - low pressure line is cold. Also at idle, my low line PSI is 43-48 and high line PSI is 175 (very low from what I'm told).
When I rev my car, it slowly gets warm. Reving the car at 2500-5500 for 1 minute, my low line PSI will shoot up to about 65-70 and not be cold anymore; the high line PSI goes down to about 150.
Compressor clutch is engaged all the way, but I cannot tell if it is slipping at all when I rev (it's definitely still engaged though)...
Just got my car evac'd and recharged by an A/C specialist. Still the same thing. He's not 100% sure what it i but thinks it may be an internal compressor failure. I'm looking for more expert assurance.
Re: cool AC only when idling, warms up when revving
Let me guess, since you failed to provide important information:
You have a vehicle correct? Ask the kid next door what year, what model, etc., and post that, might help someone actually help you.
Aw come on Cusser - we are supposed to use the crystal ball Tim sells! Did you not buy one yet?
A quick look says it is a 1984 Lada, with the infamous Russian copy of the Wing Cell compressor. It most likely has a cracked vane, and is low on pressure.
httran5
Post by httran5 »
Thought I was being super detailed but I guess I overlooked at the basic stuff. I edited my post. :)
Recover the system & weigh it - probably low on charge.
httran5
Post by httran5 »
Even though it just got recharged?
anderson0220
Post by anderson0220 »
Cusser wrote:Let me guess, since you failed to provide important information:
Aww.. That's rude? Lol. But she's right. A little bit details will help. ;)
