Im doing a big service on the ac system, and thinking about filling it with PAO 68 oil from manufacturer Hella. Originally the system is filled with ND8 oil, witch according to denso is equivalent to double capped PAG 46. The PAO 68 oil is, according to Hella, said to have the benefits of being non-hydroscopic. So if the system in the future would ever to be opened to atmosphere for a longer time, the oil wouldn't be affected and no need to change it with a system flush. The oil is also non agressive to the rubber seals in the system, witch would eventually keep the system closed and working for a longer period of time. AC systems often stoppes working because the seals gone bad so the refrigerant (R134a) leaked out. It seems that the PAO 68 is a much better oil and will work flawlessly in my system. BUT when asking a mechaic the answer is nono, it is a universal oil and I'm better of using the original ND8 oil.
Anyone with a good explanation to witch oil is the better choice?
