Here's update:
TXV is replaced (Denso). Didn't replace dryer because it one piece with condenser.
Result - same issue. Ran tests with AI:
1. Post-Replacement Baseline Test (Hot Weather)
• Conditions: 86°F ambient temperature.
• Gauge Readings: 45–50 PSI (Low Side) / 230–250 PSI (High Side).
• Behavior: Short-cycling was minimal, and the vent air temperature stalled at 63°F.
2. Water Hose Mist Test
• Conditions: 76°F ambient temperature, spraying water directly onto the condenser.
• Gauge Readings: 30–60 PSI (Low Side) / 80–100 PSI (High Side).
• Behavior: Over-cooling the condenser caused the high side to plummet, triggering continuous compressor short-cycling while vent air stayed at 63°F.
3. Stabilized Dry Test (Mild Weather)
• Conditions: 70–74°F ambient temperature with the condenser completely dry.
• Gauge Readings: 40–65 PSI (Low Side) / 130–170 PSI (High Side).
• Behavior: The compressor clutch engaged for 7–10 seconds per cycle, and vent air remained at 63°F.
4. Physical & Component Checks
• A/C Line Temperatures: The low-side pipe felt cold but not freezing, while the high-side pipe was merely warm.
• Condenser & Drier Temperatures: One condenser pipe felt slightly hot, whereas the second pipe and the receiver-drier felt significantly hotter.
• Shutdown Equalization: After turning off the engine, high and low pressures equalized very slowly, confirming your compressor's internal reed valves are sealing properly.
• Old TXV Inspection: No metal debris, flakes, or sludge were found inside the old valve.
AI says next step - replace condenser.
2019 Nissan Frontier AC troubleshooting (Video link attached)
Re: 2019 Nissan Frontier AC troubleshooting (Video link attached)
There's no way that the system is going to provide decent cooling with low-side pressures of 40 PSI and higher.
Have you scanned the vehicle for DTC's? If no codes, I would investigate the possibility of a blockage next.
If I recall correctly, you've already replaced the TXV with an OE unit, so we can probably rule that out. If the blockage isn't located in the condenser and/or the integral R/D, then it's in a line, hose, or muffler. Changing the condenser and R/D assembly for a relatively small investment might provide the solution.
