Improving vac pump perf
zz28zz
Post by zz28zz »
While awaiting parts to arrive, I dug out my old Robinair 15400 pump and micron gauge. Both have been in a box for the last 18 years or so. Warmed-up pump and replaced the oil (with Robinair oil). Connected micron gauge and it pulled down to abt 180 microns within a couple of mins. This pump is rated at 15 microns. I think it will be good enough but wanted to see if there was a quick fix or if I need to install a seal kit. I suspect the shaft seal has hardened over the years.
Thoughts?
Re: Improving vac pump perf
If your vacuum pump will evacuate the system to about 500 microns, that's all you'll need. Ensure that the vacuum holds.
For an 18-year-old pump that evacuates to 180 microns with an oil change and a direct connection to the micron gauge, that performance is pretty good. Double-check your micron gauge that the sensor is clear of any debris and that it doesn't have any oil in it.
zz28zz
Post by zz28zz »
After messing with the hose connections, I'm now able to achieve 130 microns in 3 mins and down to 91 microns after abt 20 mins. Holding it is another matter. If I close pump isolation valve, vacuum goes over 500 microns in a few mins with just the micron gauge connected via 3 ft hose. Still not sure if it's moisture boiling off, hose outgassing or something leaking.
A reading of ~500 microns, excellent for MVAC systems, is an extremely small, measured amount of vacuum that you can't even notice on a high-quality Manifold Gauge Set's low-side gauge in Inches of Mercury (InHg). That said, temperature, pressure, and material composition can also affect outgassing, and hence, rising micron rates.
When measuring vacuum with a micron gauge, outgassing of the material in an MVAC system—that is, the oil and desiccant (even if new), hoses, seals, and etcetera—plus air and moisture that might be trapped in the system, can affect the reading observed on a micron gauge.
The micron gauge should eventually "settle down" after evacuation to less than, say, 1,000 microns in an MVAC system, unless the system or equipment has a leak. Be aware that a micron-level leak probably can't be detected even by a sensitive electronic "sniffer" unless it's a substantial leak (non-micron-level).
The best you can do is to either change every o-ring, seal, and hose in your vacuum pump setup in an effort to prevent any equipment leakage, or (presuming your setup isn't leaking) continue evacuating until the micron gauge stabilizes to *some* arbitrary reading, unless the system itself is leaking.
zz28zz
Post by zz28zz »
Last night I played with it some more. Connected my brand new 3-port Fieldpiece manifold and all 3 brand new Yellow Jacket Plus II hoses to vacuum. Got down to 370 microns after a few mins. Shut-off pump isolation valve and shut-off pump. Today I'm at ~750 microns, so think I'm OK in regards to leaks with test equip.
Searching HVAC vacuum tests shows most recommend that sys should hold below 500 microns for 20-30 mins, and others say it should hold below 500 microns overnight. May be some are referring to HVAC systems other than automotive??
Don't think my system will hold below 500 microns for more than a few mins since the test equip by itself can't do that due to outgassing??
Anyway, I'm headed to the shop for what will certainly be a long crappy job. With a little luck, I'll have it evacuating this evening and see what's up.
zz28zz wrote: Sat Oct 03, 2026 1:00 pm Last night I played with it some more. Connected my brand new 3-port Fieldpiece manifold and all 3 brand new Yellow Jacket Plus II hoses to vacuum. Got down to 370 microns after a few mins. Shut-off pump isolation valve and shut-off pump. Today I'm at ~750 microns, so think I'm OK in regards to leaks with test equip.
Calculate that 750 microns of mercury (µmHg) minus 370 µmHg equals 380 µmHg—or converting from microns, a mere 0.015 inches of mercury (InHg), you realize that it's not possible to even read such a very small amount of vacuum on the low-side gauge of your Manifold Gauge Set (MGS), which is most likely calibrated in *individual inches* of mercury. Since we're dealing with microns of mercury (µmHg) and not inches of mercury (InHg), I simply wouldn't worry about a minuscule difference on your micron gauge of 380 µmHg, and I'm guessing, neither would a pro shop.
Professionals definitely wouldn't do this (time is money), but you could choose to continue to evacuate until you see the micron gauge stabilize at an arbitrary reading of, say, less than 1,000 µmHg, and call your evacuation procedure good.
zz28zz wrote: Sat Oct 03, 2026 1:00 pm Searching HVAC vacuum tests shows most recommend that sys should hold below 500 microns for 20-30 mins, and others say it should hold below 500 microns overnight. May be some are referring to HVAC systems other than automotive??
HVAC (Heating Ventilating and Air Conditioning) refers to residential and business systems that are different from automotive systems, which are referred to as MVAC (Mobile Vehicle Air Conditioning) systems.
zz28zz wrote: Sat Oct 03, 2026 1:00 pm Don't think my system will hold below 500 microns for more than a few mins since the test equip by itself can't do that due to outgassing??
No need for evacuation to be a "crappy" job. I think you're getting too hung up now in the minutiae of the evacuation process. Just use your new MGS (forgetting about the micron gauge for the time being), evacuate down to ~29.9 InHg at sea level (higher elevations will yield a correspondingly higher vacuum reading), verify for 15 minutes whether the vacuum holds, and if it does, call it done.
zz28zz
Post by zz28zz »
Yes I'm aware you can't accurately read deep vacuum using a gauge set. That's why I have a micron gauge.
My understanding is that if you can pump down below 500 microns, isolate system and if it stabilizes and doesn't go above 1000 microns in a hour, there's no significant leaks. Just out gassing that stops at a certain vacuum level. Serious water vapor removal starts at 500 microns and below. New hoses are known to out gas due to solvent still in the rubber from the manuf process. In the past, I've included the gauge set in the evac process, but from what I've learned recently, it better to connect the pump directly to one side of the system and install the micron gauge on the other side.
Many years ago, I worked in a shop that did A/C work along with other automotive stuff. The "pros" are working against the clock and the system only has to last until the warranty expires. This, and the price of auto repair in general, is the reason I do my own work.
The crappy part is replacing everything and also doing some other "while I'm at it" items like new belts, idlers, and tensioners. Also pulled the radiator and gave it a good external cleaning. Had to flush evap and lines too.
C5 vette A/C systems are not designed to be worked on. Just to remove the compressor means pulling the right front wheel, drop the exhaust pipes, remove the batt and then remove the right side exhaust manifold.
The evacuation and charging is the fun part.
Got the A/C system closed up and purged with argon (don't have nitrogen currently available). Pressurized system to 125 psi and letting it sit for a few hours to see if I have any leaks. If that passes, will start the evacuation and finish putting humpty dumpty back together again.
Be sure to let us know how you make out.
zz28zz
Post by zz28zz »
Inert gas (argon) pressure leak-down test passed. Didn't loose any press over-night. Vacuum test passed. Got down to 470um then ran pump for another hour. Isolated pump and vacuum climbed to 795um and stabilized after 1 hr. Called it good and charged system.
Used 2 can exactly. Using scales with 0.1 oz resolution I measured a known empty can against the can I felt was as empty as it was going to get connected to the low side. They weighed the same. (Same can manuf) I did use an old partial can I had to do the charge hose purging. EDIT: also bled pressure trapped in high-side hose into low side to get the last little bit of refrigerant (hose ball-valve closed at high-side port for this step).
Long story short, I'm feeling pretty confident I got the charge right.
Got the entire first can in just using the 795um vacuum.
For the second can, I set-up the car as follows:
1. Eng at operating temp
2. A/C on
3. Recirc mode OFF
4. Big fan in front of car
5. Eng speed at 1700 rpm
6. AC Fan on HIGH
7. Windows/doors open
8. Fluke temp sensor in center vent with display positioned where I could see it.
Noticed vent temp bottomed at 46 degs when I had almost finished with second can. By the time I finished the second can, the vent temp climbed to 47 degs. This correlates to my old-school method of topping off a sys with an unknown charge using the same 8 conditions.
Getting 42 deg air at center vent with outside temp of 90 (R/H=close to 80%) and not in recirc mode, mid speed fan and on the road. Feeling pretty good abt it so far. Just hope it makes 18+ years again. Noticed compressor is quieter than the AC Delco one was. That's gotta be a good sign.
