I'm dealing with the problem of expansion valve bolts that do not want to let go.
There must be a good bit of corrosion on the tips of the threads that were inside the evap housing.
They will turn about 4 turns then lock up solid.
I sprayed them with PB Blaster and right now I'm waiting 1/2 hour to go try again.
If that fails I think I'm faced with drilling the heads off so I can remove the expansion valve then try to get the remaining studs out.
I think the evap core is good (I'll pressure test it) so I was gonna re use it but if the evap core threads strip it's a fairly involved job to remove the dash to replace the evap. Trying to avoid that.
Any trade tips on getting these boogers out?
If so, thanks!
Badly stuck expansion valve bolts - Dodge Grand Caravan
Re: Badly stuck evaporator bolts
Can you get in there with an oxy-acetylene torch (#1 tip or smaller) to heat-up the ends of the studs cherry red? If so, the nuts will come right off. Better wash off all the PB Blaster, though, and have a fire extinguisher ready.
Hello JohnHere!JohnHere wrote: Fri Aug 21, 2026 2:57 pm Can you get in there with an oxy-acetylene torch (#1 tip or smaller) to heat-up the ends of the studs cherry red? If so, the nuts will come right off. Better wash off all the PB Blaster, though, and have a fire extinguisher ready.
No sir. There is no access to the bolts tips. Maybe if I removed the entire dash assembly I could get to them from the inside of the vehicle. But I'm really wanting to avoid that if possible.
I don't think there are any nuts. AFAIK, the bolts thread directly into the evap core on the other side of the firewall.
So it must be the last three or four threads of the bolts that were exposed to moisture inside the evap housing that corroded and it's that small 3 or 4 threads that are jamming when trying to unscrew them.
I was also thinking that IF I drilled the heads of the bolts off, I could then move the expansion valve out of the way and that just might allow me to heat the bolts with a torch a bit. Still not sure that would do the trick. At least I could get better access to the bolt threads and keep soaking them with PB Blaster then turning them back and forth hoping to eventually free them.
Worst case scenario...I have to remove the entire dash assembly, steering column, mirrors and all the dash fascias and take the dash out then remove the entire HVAC assembly to put a new evap core in there. Tedious but if I have to I will. One of the most tedious things about removing Gen 4 Dodge Caravan dash assemblies is that everything is held together with the most brittle plastic I've ever seen. Trying to unscrew trim screws almost always means breaking off the entire screw stanchion. The trim and fascia parts end up with so many broken pieces that screwing the assemblies back together and reinstallation is near impossible. It is very common when I take these dash assemblies on the older Dodge Caravans apart that I spend one or two days just rebuilding the posts and screw stanchions or cracks in the HVAC face plate assembly. Super brittle. The good news is that once I have done this rebuilding process they usually never break up again. I have 5 Dodge Caravans. All Gen 3 or Gen 4. If you have any kind of Dodge or Chrysler vehicle you probably know exactly what I'm taking about.
These are my thoughts anyway.
Re: Badly stuck expansion valve bolts
Since you can turn about four turns, I'd keep trying the PB Blaster and turning through those 4 turns, then more Blaster. That's what I'd do, and be patient...Diametric wrote: Fri Aug 21, 2026 1:57 pm I'm dealing with the problem of expansion valve bolts that do not want to let go.
Thank you Cusser.Cusser wrote: Sat Aug 22, 2026 5:23 amSince you can turn about four turns, I'd keep trying the PB Blaster and turning through those 4 turns, then more Blaster. That's what I'd do, and be patient...Diametric wrote: Fri Aug 21, 2026 1:57 pm I'm dealing with the problem of expansion valve bolts that do not want to let go.
Good advice.
I only hope the torx slot on the bolt head holds up. It seems to be slowly rounding out. Once the tool can no longer get a good bite I think at that point I'll have no choice but to drill.
If I end up going that route, do you think applying heat to the remaining stud would make any difference?
Well, my patience ran out, and the torx slot started wollering out.
After trying to work the bolts back and forth for about an hour, applying PB Blaster along the way, and getting nowhere I decided to drill the heads off the bolts.
I can tell you that trying to do that with HarborFreight Titanium drill bits doesn't cut it. I can give the Titanium bits an honorable mention against the grade 8 or grade 10 hardened bolts, but they were definitely not up to the task.
Fortunately, I also had a set of HarborFreight Cobalt bits and alas, they made quick work of those same bolt heads. It really is an amazing difference.
So with both bolts decapitated......I still can't get the expansion valve off (yet). Not sure what's holding it? It wiggles and moves and has about 1/4 inch gap between the mounting block and the Exp Valve, but it just won't let go and slide out. I kept thinking it was a small bit of the head of one (or both) bolts still hanging on just enough to keep it from coming off, but no matter how much more I drill the bolt studs....no go.
I can't say this job is a whole lotta fun at this point.
In the photo below, you can make out (barely) the remaining stud of the now decapitated bolts. Bad angle. I'll try to get another better shot and post it. I'm going out now to get a small diameter punch and play Whack a Mole with those decapitated studs to see if I can get them to let go.
Anyone else see that strange looking section of hose next to 2332 in the photo above?
I need to investigate that. I wonder if that could be a defective hose that is collapsing under vacuum or just an optical illusion?
Re: Badly stuck expansion valve bolts - Dodge Grand Caravan
That hose is strange looking, all right. It appears to be formed that way, but who knows? Dodge might have done that for clearance purposes.
What year is your van? Using the year, you could look-up the van's OE A/C parts and see what turns up (whether the replacement line is the same).
Hello JohnHere!JohnHere wrote: Sun Aug 23, 2026 7:49 am That hose is strange looking, all right. It appears to be formed that way, but who knows? Dodge might have done that for clearance purposes.
Yes, strange. Now that I just got the expansion valve out I'm going to take a close look at that hose.
This van is a 2001 Grand Caravan.
It's out....finally
Well that was not fun.
It took me quite a bit to get the heads drilled off clean enough to pull the valve out. It's very difficult to drill a concentric hole in that bolt, which is recessed and through the T-25 machined slot. Seems I went off center at some point and ended up drilling at an angle which left a small piece of the head clinging on the side of one bolt which added and extra day and 4 hours to the removal process.
I think if you could get the holes drilled dead center and straight down the center this would be a fairly quick job (with Cobalt drill bits)
Here's a few pics of the removed parts.
The final, butchered expansion valve after all the drilling The back side of the Exp Valve mounting plate. Aluminum with steel bolts...dissimilar metals problem.
Rust! I knew it! I'm not sure exactly what yet....but I'm gonna paint the replacement bolts or use stainless or something to try and prevent this if ever I need to change this Exp Valve again. I'm gonna guess from this that this expansion valve is the original from 2001. I'm sure these are grade 8 or grade 10 bolts. It took Cobalt bits to drill them out. Another, maybe more risky procedure to remove these bolts came to mind after it was all removed. If you're extremely careful, once you turn the two bolts as far as they can go before they jam tight, you'll get a nearly 1/4 inch gap between the mounting block and the expansion valve. in theory, you could (being extremely careful) use a dremel tool with a cutting wheel to cut the bolts in that 1/4 inch gap. Obviously it depends on whether you have room to position the tool to get the cutting disk in there. Maybe there's a better tool that you can think of that might do that? Well, this still doesn't guarantee that I won't have to remove the entire dash to replace the evap core. In fact in this case, since it's a 2001 and it appears virgin, I'm thinking it might be dumb NOT to go ahead and replace the evap core. If it's also original I have to assume it's either leaking or not far from it. In Gen 3 and Gen 4 Dodge Caravans (from my experience since I own 5 of them), 10-11 years seems to be the evap core lifespan depending on where it was parked most of the time. Under trees make it 6-7 years.
I have a 1999 Grand Caravan that has an evap core that I replaced 12 years ago and I'm currently replacing that one so this one is gonna have to wait until I finish the 1999. If you own a Dodge Caravan you just might find this a helpful read. All others...meh...maybe.
