2011 Fusion, A/C works then switches to "heat from Hell" Long post
aribert
Post by aribert »
2011 Fusion SE 4 cyl, base A/C (not dual zone, not auto temp control). 175K miles. A/C appears to work good, nice cool temps out of the vents. Suddenly the A/C quits cooling and maximum heat comes out of the vents. A/C controls have not been touched when this happens. On a restart A/C may work fine for an extended period of time or switch to the "heat from hell (my wife's car and her description) after about 20 to 30 seconds of cold out of the vents. This problem also occurs when the HVAC setting is in vent mode. No adjustment to temperature control has an effect. Do not think it has happened while in heat mode.
This first occurred in '19. I replaced the HVAC control module (rebuilt Dorman, lifetime warrantee) and all was well until June '24 when the problem reoccurred. Replaced the HVAC module again along with the blend door actuator and problem reoccurred in Oct of 24. Replaced the HVAC module again (3rd time) but the heat from hell occurred during first drive after HVAC module replacement replacement. Installed a Motorcraft blend door actuator - no improvement. For the summer of '25 I set the A/C to max cool, removed the blend door actuator from the HVAC module (leaving the blend door module electrically connected and zip tied up under the dash). A/C worked great all summer/fall but unable to control cabin temp other than fan speed or A/C on/off.
I acquired scan software (Forscan) and the Ford workshop manual. One HVAC DTC: related to low batt voltage. Followed the test procedure for batt voltage (passed) and the direction was to replace the HVAC control module. 4th HVAC module replacement worked OK after install but heat from hell the next day driving. Checked DTCs - two this time. Both DTCs were communication errors between IPC instrument control panel and HVAC module and FDIM front display interface module and the HVAC module. Following the manual, it appears the HVAC module is at fault - I'm on the ragged edge of understanding this.
Has the Dorman rebuilt module become junk? Are there other options for an HVAC module (I have not found anything else)? I'd really like to solve this problem correctly, but I am beginning to daydream about machining a coupling/lever to mount on the HVAC asm and having a push/pull cable actuate the blend door (like the good old days).
Re: 2011 Fusion, A/C works then switches to "heat from Hell" Long post
aribert wrote: Mon Apr 20, 2026 7:34 pm A/C appears to work good, nice cool temps out of the vents. Suddenly the A/C quits cooling and maximum heat comes out of the vents. A/C controls have not been touched when this happens. On a restart A/C may work fine for an extended period of time or switch to the "heat from hell (my wife's car and her description) after about 20 to 30 seconds of cold out of the vents.
We had similar symptoms on a GMC Yukon a decade or so ago. The problem was traced to an in-dash actuator which moved the air flap to heated air instead of remaining in the cold air mode. I replaced the actuator and "taught" the ECU to recognize it to fix.
aribert
Post by aribert »
The part you describe is what I refer to as the blend door actuator, replaced twice, second time purchased a Motorcraft branded actuator (apparently the Murray branded part I first purchased was reported to be a bit flakey). When I replaced the HVAC control module, I followed the Ford calibration protocol of pulling the HVAC fuse & wait one minute, ign on for 30 sec, ign off and reinstall fuse and ign on for 30 sec before any functional tryout of the HVAC system.
It certainly seems like the Blend Door Actuator is receiving a false signal. But before we go to the control module again, let's examine a few other things that you might be overlooking.
Seems simple, but have you checked the cabin air filter? A partially clogged or fully clogged filter sometimes can really throw-off an MVAC system.
Even though you aren't seeing DTCs on your scan tool, have you checked/tested both the Ambient Air Temperature Sensor and the Cabin Air Temperature Sensor? A fault in either one or both can cause the problem you've described.
I hear you about the cable-controlled blend door :D
aribert
Post by aribert »
JohnHere wrote: Wed Apr 22, 2026 12:43 pm ....have you checked the cabin air filter? A partially clogged or fully clogged filter sometimes can really throw-off an MVAC system. No, have not replaced (or even checked) the cabin filter in half a dozen years. Never considered that the filter could be a culprit.
....have you checked/tested both the Ambient Air Temperature Sensor and the Cabin Air Temperature Sensor? A fault in either one or both can cause the problem you've described. No, I have not checked either sensor, I will need to check if the car even has an ambient temp sensor(there is no info display for such)
Thank you for the suggestions - things to look into the next few evenings!!!
johnarden
Post by johnarden »
That’s a tough one… and honestly, you’ve already gone way deeper into it than most people would.
At this point, it really doesn’t feel like the HVAC module itself - 4 replacements all doing the same thing is a big clue. Feels more like something making the module lose its mind.
The way it switches from cold to full heat suddenly (without touching controls) makes me think the system is defaulting the blend door position - usually happens when the module loses proper signal, power, or communication.
Couple of things I’d look at:
Power/ground to the HVAC module – even if battery voltage is fine, a weak ground or slight drop can cause weird behavior like this
Connectors & wiring behind the dash – something loose, corroded, or a pin not seated right could explain the random switching + comm codes
CAN communication issue – since you’re getting IPC/FDIM errors, it might not be the HVAC module at all, but something on the network glitching
You already proved the AC system itself is fine by locking the blend door cold — so this is definitely control-side
Also… yeah, Dorman can be hit or miss, but it’s hard to believe all 4 are bad in the exact same way.
Honestly feels like one of those annoying electrical gremlins — probably something small causing a big headache.
And not gonna lie, your manual cable idea… I get it 😄 sometimes simple just works.
One thing that might help narrow it down — when it suddenly goes hot, do you hear the actuator move, or does it just switch with no sound?
Cusser wrote: Tue Apr 21, 2026 6:08 am
I should add that in the months leading up to the replacement, I disconnected the electrical harness from the actuator and turned the actuator with a screwdriver which kept it in the AC mode. Of course, one could always "catch it" in the AC mode and then disconnect the harness....
