R-134A System Schrader Valve Core Size
jz57
Re: R-134A System Schrader Valve Core Size
Post by jz57 »
Pix are added
jz57
Post by jz57 »
Thanks very much for the help
tbirdtbird wrote: Tue Jul 23, 2024 6:11 am Tim, can you help with posting his images?
To the poster, you hit the Attachment tab at the bottom left, and then ‘add files’, then follow the prompts, it should work.
I myself was never able to get the drag and drop function to work.
JohnHere wrote: Thu Jul 25, 2024 2:27 pm The Forum software probably is preventing the picture from posting if it isn't 256KB or less in size.
You only have half of the tool set. The other (missing) half will be able to accommodate the larger Schrader valves pictured. A tool supplier for professional MVAC technicians should have them or can order them for you. The knurled double-sided tool is for removing and installing the Schrader valves after the refrigerant has been recovered and the system is empty.
