UPDATE....
I put in 2 can of freon, pressures good L 32 H 133.
Works great now, Ice cold!
1991 S10 Issues
Re: 1991 S10 Issues
I think JohnHere mixed this up.JohnHere wrote: Thu Jun 06, 2024 10:49 am If the low-side running PSI is approximately in the mid-20s to mid-30s, then the pressure switch on the accumulator should be "closed," or infinite ohms on a multimeter, which would cause the compressor to engage. If a correctly functioning pressure switch senses abnormally low or high pressure, it would "open," disengaging the compressor. So the zero ohms reading that you tested means the switch is "open."
"Closed" would be continuity or very few ohms resistance, likely less than 1 ohm.
"Open" would be infinite resistance, no continuity.
Good, don't mess with it. By the way, the pressures you posted are semi-worthless without specifying rpm (typical pressures are read at about 2000 rpm) and outside/ambient temperature.philipk1965 wrote: Wed Jun 12, 2024 5:56 am UPDATE....
Re: 1991 S10 Issues
Of course! That's what I was trying to sayCusser wrote: Wed Jun 12, 2024 6:51 am JohnHere wrote: ↑Thu Jun 06, 2024 1:49 pm
philipk1965
Re: 1991 S10 Issues
1800 RPM
Air temp 74 degrees F
relative humidity 54%
