Open or Short in the Mode Control Motor Circuit
mrovet
Post by mrovet »
I have a 2009 Honda Civic. The AC is not blowing cold air.
I ran a climate control diagnostic and got code #4 An open or short in the mode control motor circuit
Can anyone provide me with step by step directions on how to fix this?
Thank you in advance
Re: Open or Short in the Mode Control Motor Circuit
mrovet wrote: Mon Jun 03, 2024 11:52 am I have a 2009 Honda Civic. The AC is not blowing cold air.
Since the A/C Self Diagnostic indicates a Code #4 (open or short), the problem might be as simple as a bad A/C relay or a blown fuse. IIRC, both are under the hood in a panel on the driver's side, and they can be checked for continuity with a multimeter.
mrovet
Post by mrovet »
Thank you. I replaced both and the issue is still there.
I don't have an electrical diagram or a listing of Diagnostic Trouble Codes (DTCs) for your particular Honda. If you want to DIY, consider purchasing a short-term subscription to either AllData or Mitchell's, which will have all of the factory information that Honda technicians use for diagnosis and repair. Otherwise, you'll probably have to take your car to an independent Honda specialist or to a dealer to get to the bottom of this.
Wes
Post by Wes »
mrovet wrote: Wed Jun 05, 2024 3:37 pm Thank you. I replaced both and the issue is still there.
Hey did you ever figure out the issue with your a/c? Mine has the same exact issue.
Wes wrote: Fri Aug 09, 2024 2:11 am Hey did you ever figure out the issue with your a/c? Mine has the same exact issue.
Why not start a new topic for your own vehicle? Most likely, you'll get more customized responses that way.
