What CFM for condenser fan
I am adding electric pusher fan to my condenser. Space allows for two, 12" fans side by side. I'm curious what CFM range per fan I should be looking at, as there is a wide range of options available.
Re: What CFM for condenser fan
Suggest you look up specs for Spal fans, (link deleted) they are the best.
If you have room to use them as pullers that method works better.
Reason: Links to outside businesses not permitted.
As large, and as much CFM as will fit.
What vehicle are we talking about here?
