Hi,
I have question about Denso 471-6058 A/C Compressor with Clutch, what kind of oil it has been used for that model and is there any idea because I didn’t get it what is this FD48X6, thanks
Compressor Oil type
Compressor Oil type
- Denso 471-6058
- image001.png (15.43 KiB) Viewed 14219 times
Re: Compressor Oil type
Thanks Tony. So, any PAG oil will be fine or there are a specific one.
Denso compressors using R-134a refrigerant normally take PAG-46 (ND-8) oil. If you can find double-end-capped PAG-46, so much the better.
No!Boss2000 wrote: Sat Jul 22, 2023 8:13 am Thanks Tony. So, any PAG oil will be fine or there are a specific one.
To a degree, you can't even go by OE standards anymore. Most compressors on sites like the tag posted use import compressors. A Nippondenso 10pA15C and an import 10PA15c may use different PAG oils. You need to have a source that knows what product you're buying. In the example, would running Pag 46 be harmful? Probably not, but if the import was designed for Pag 100. It would be best to run the proper Pag oil.
Aw come on Tim. If it fits it ships! It is not staying on the lot very long...
Out-of-sight warranty applies with no exceptions.bohica2xo wrote: Sat Jul 22, 2023 9:19 am Aw come on Tim. If it fits it ships! It is not staying on the lot very long...
You have to excuse the snarky replies - some are jealous that some made a fortune as a used car dealer.
If I post that today is Saturday, someone will complain that on another planet in a galaxy far, far away it is actually Tuesday.
Tony, I don't think much about what you claim to have done.tony1963 wrote: Sat Jul 22, 2023 9:36 am You have to excuse the snarky replies - some are jealous that some made a fortune as a used car dealer.
This site is to help others with "proper" repairs and has been doing this since 1997. In this case, the proper Pag oil should be recommended. As well as to instill the best performance and longevity of the component. If you don't know. A mediocre response is not helpful.
Stop whining and be helpful!
Thanks all for your valuable information but still until now I didn’t get the answer because I already asked the company and then they sent me back what you see now FD48X6, I have asked them again what is this and are there any recommendations, until now I didn’t get the answer from them
