Would never consider doing that to evaporator cores, condenser, TXV’s or anything other than just the straight tubes (not the muffled ones either) but that was why I asked before I did anything
2006 Lincoln Navigator Replace Stock Scroll compressor w/piston type?
BakoNavi23
Re: 2006 Lincoln Navigator Replace Stock Scroll compressor w/piston type?
Tbirdtbird, I wasn’t even thinking about introducing water into any components still in the car, I was just talking about the rubber and metal connecting tubes that I have already removed.
BakoNavi23
Hey Tim,
Do you sell tools too?
I can get the flush tool and the vac pump and guages on Amazon for about $170+ tax for 4 cfm pump.
I’d be happy to buy piston compressor, tools, flush fluid and whatever else you think I need to do the job right the first time from you.
Since my vehicle has seprate evaporator core in back I’m assuming this means I have to crak open the stuff in the back and clean everything individually (except TXV’s and condenser core, of course).
Guessing that also means I need to replace both front and back TXV’s since they cannot be flushed?
That oil looked pretty damn clean, really hoping I don’t need to replace condenser since I know that cannot be flushed either....
Email the links, and I'll check if I can match. Not all parts/tools are the same.
email: info@ackits.com
BakoNavi23
"I was just talking about the rubber and metal connecting tubes that I have already removed."
Doesn't matter if they are installed or removed.....never water based anything...you will never dry it all out no matter how it seems or what you think is happening
Back when AMA had a shop. We broke down each component and flushed it individually. On rare occasions, we would flush a line and condenser simultaneously.
Sorry to chime in late like this, not reading the forum very often I guess.
Compressors are designed to leak oil out of the shaft seal. The oil lubricates the seal, there is a little felt ring in the compressor nose to mostly catch the oil, and also to keep customers from complaining about it.
Your oil looks beautiful, might consider keeping the unit you have if you can live with the performance.
Piston will definitely have better idle performance, scroll will have better higher RPM performance.
