hi
sight glass full
suction line very cold
approx expected weight charge
approx pressures  35/200
assuming condensor and evap clean
good to great airflow over condensor
fast idle 1500rpm yes
bypass heater core/tap  ie block water flow
controls set to recirculate NOT FRESH
system flushed and reoiled with correct type and quantity of oil
						Underwhelming cooling performance after complete A/C restoration
				swampy 6x6
Re: Underwhelming cooling performance after complete A/C restoration
The last meaningful post in this thread was in July. Do you think we are not following the replies? You are either a spammer or an HVAC guy trying to look smart in MVAC
Suggest finding some other forum to post on and become famous
