Flush
Seanrice
Flush
Post by Seanrice »
I have a 70 chevelle that had a working,although poorly,ac system
I have replaced everything and had the POA valve restored
New evaporator,compressor and parallel condensor
Going back with r12
The hoses look to be in like new condition
They have a been disconnected and we're open on the ends for about two weeks,I have placed tape over the ends since then to keep clean
Should I flush those before reinstallation or will I be ok
If I do need to flush what is the best way and can I flush through the muffler
I should note,my plan is to assemble everything and take it to a professional to pull a vacuum and charge
Thank you
Re: Flush
Flushing depends on the type of environment the hoses were exposed to.
Dusty, bondo dust, metal grindings from an air tool, et etc???
If none of the above apply then I personally do not think you need to flush.
You cannot flush thru a muffler
Should you decide to flush, we use naphtha here. Very quick drying, and leaves no residue. We do NOT prefer mineral spirits. You would still need your air compressor to dry the insides out, although you will be exposing the insides to the moisture and slight oil mist in the compressor air.
We have a commercial refrigerated air dryer/cleaner on our air line because we also paint cars, and that air must be squeaky clean.
But a good vacuum pull down should suffice after you are done flushing and drying.
Good luck
Re: Flush
You didn't mention a new drier/accumulator.
Re: Flush
Nice catch, Cusser!
Seanrice
Re: Flush
Post by Seanrice »
Yes ,that is a good catch
I am replacing the dryer
The hoses were just in my garage so I believe I will be ok
Thanks everyone
Re: Flush
Per our phone conversation.
43-4054
43-3106-1
