gauges leak out freon after use
Re: gauges leak out freon after use
Most quality vacuum pumps have both R12 & R134a ports to attach your hose. As for your tank, did you buy it for industrial use. They might have a different fitting.
Similar to this tee.
penguins25
Post by penguins25 »
ok it does fit on the freon tank but not the vacuum pump
need pix
penguins25 wrote: Tue Jul 27, 2021 7:45 am ok it does fit on the freon tank but not the vacuum pump
Post a pic of the vacuum pump and fitting.
penguins25
pic
My eyes might be bad, is not the hose attached to the pump in your image?
"My eyes might be bad," LOL
you knew you would get an LOL out of that
penguins25
no the hose is at the top of the fitting
the white plastic thing that holds the cap is where it threads to
penguins25
it wont thread on the fitting
I'm lost!
That tee is R12 and R134a. Your hose is attached to one or the other depending on your gauges.
