JohnHere wrote: Sat Jul 17, 2021 12:12 pm
Harry Seaward wrote: Sat Jul 17, 2021 10:33 am
At any rate, all of the oil was removed, and i weighed in 6.5oz, so if there are still problems, it won be due to excess oil.
Better double-check that oil amount before you button everything up because you still might have a big problem. Unlike a refrigerant charge, the oil amount is measured in fluid ounces, not by ounces of weight.
I didn't see this in time, and don't really have anything to get that precise of a measurement anyway.   The compressor has a 1/3 fl-oz range on the stated capacity and the shop manual says 1/3 fl-oz for "each line and hose".  That seems to be a bit loosy-goosey considering some lines and hoses are twice the length and diameter as others.   Hopefully PAG46 is +/- 1 fl-oz volume at 6.5oz weight.
Everything is back together and functioning.  I noticed that the condenser fan didn't seem to be blowing very hard, so I replaced that while I had everything apart.  The low side is lower, but the fan didn't make any difference on high side temps.
Here's the data:
105 degrees ambient and 33% humidity (humidity based on weather.com for my area)
1500 RPM
40psi low side, 325 psi high side (see below).
Condenser inlet is 178 degrees, outlet is 150 degrees on the flat part of the pipe side of the fittings - I used a digital meat thermometer that gives perfect 130 degree readings on my medium-rare steaks.
Using same thermometer, vent temp is 65 degrees at 1,500 rpm in my 105 degree garage.  It dropped to 55 on the 30 minute drive to return the car to my daughter at 4:30pm.
It's condensing water like crazy - the low pressure line with the service port was pretty cold and coated with pretty good sized beads of water, and the evap drain tube was dripping about every 1/2 second sitting in my garage at 1,500 RPM.  It's just not blowing as cold as I remember.  And maybe I'm thinking of times when it was 5% humidity, who knows.  I know the humidity kills the efficiency.  My daughter's boyfriend said it got down below 40 on the freeway a couple days ago.  If I had known that, I probably wouldn't have torn into it again today.
I've determined that my expectations are just too high, because on the return trip in my wife's '16 Pilot her vent temp was only 51. Something that is odd to me, this video (
https://drive.google.com/file/d/1A2YUEp ... sp=sharing) shows the gauges fluctuating, and I noticed that the vent temps would also fluctuate, although I couldn't see the gauges and the vent temp at the same time, so I don't know if it was a direct correlation between the two.  Anyway, I've had gauges on this car at least 20 times, and I have never seen it do this.  I seemed to remember that this was possibly an indication of moisture (or air?) in the system, so as impossible as that seemed, I vac'ed yet again to 29" and recharged, but the fluctuation returned.  It didn't seem to do it until right at the end of the first 12oz can.  I'm guessing this is something related to the new TXV, even though I had installed the exact same brand of TXV two-ish weeks before the one I just put in today.  It did settle down to about 1/4 of the fluctuation seen in that video once I got it fully charged and let it run about 10 minutes, but it still moves around like I have never seen.
So that's where I'm at.  It what it is.  There's no leaks and it's blowing 'cool'.  I'm anxious to see how it does when we get back down to our normal humidity range out here.
Note to future self: don't forget to reconnect the transmission cooler line so you don't pump 3 quarts of fluid on the ground.
