02 Silverado ac compressor problem
I have a 02 Silverado and after about 10 minutes the clutch stops working. I've tried the jumper wire on the low pressure & high pressure and switch on the back of compressor along with new relays but clutch still don't come on. Also replaced orface tube. Any ideas?
Re: 02 Silverado ac compressor problem
When you changed the OT, did you use the correct part and install it in the right direction? Did you replace the accumulator/dryer? And how did you re-charge it?
The gap of the clutch-engagement surfaces might be too wide. It should be around 0.020" or the thickness of a standard business card. A gap larger than that can cause clutch re-engagement problems as the compressor cycles.
I agree- next time "clutch stops working" get out of the truck and find a way to bump the front hub (clutch) of the compressor- chances are really good it will snap in and start working. This is a sure sign of a "too wide air gap"- Fix it by removing the clutch, and removing the thickest shim in behind it- be careful to find it when removing the clutch- it will fall out. throw the shim away and put it back together and get another 100k miles out of it.
I fixed intermittent AC clutch operation in my 1998 Nissan Frontier by removing a clutch shim back in 2019. It's still working great.
On that truck I didn't need to remove the AC compressor to do that, or even the compressor belt !!!
I think I may have found the problem. I can't figure out how to post a video to show you so I'll just say when engaged the clutch is wobbling bad. What do ya'll think?
bearing
not sure you can directly post vids here, load into youtube then link
Without seeing the video: I'd say you found the problem.Chasdrng wrote: Mon Jun 28, 2021 1:22 pm I think I may have found the problem. I can't figure out how to post a video to show you so I'll just say when engaged the clutch is wobbling bad. What do ya'll think?
Note that most times a new AC clutch assembly will cost about the same as a brand-new compressor with clutch. So likely change to a new (not rebuilt) compressor.
