Low side normal /high side low stumped
Excursion2001
Re: Low side normal /high side low stumped
Post by Excursion2001 »
tbirdtbird wrote: Wed Jun 23, 2021 7:33 am "I put all the new parts on"
John, what does this mean? That he changed out the evap and condenser as well?
If that original comp grenaded then as you know he has more problems yet.
I had trouble following his writeup especially when he said his hi is supposed to be 350
I’m sorry for the confusion I had a more detailed explanation but when I submitted it it logged me out so I had to rewrite everything but everything but the evaporators were replaced and the compressor did not blow up . it was off because the previous owner had changed the engine and he cut it off idk why but he did
Many boards will time you out when you are composing a long post. Solution is to compose in a text or word editor such as Word, etc, then copy and paste into your post.
The two evap still had their oil, (the inside is coated with the oil) I would not have used all 14 oz of oil
I have limited experience with dual systems, so let's wait for JohnHere to get back on
Excursion2001
tbirdtbird wrote: Wed Jun 23, 2021 3:46 pm Many boards will time you out when you are composing a long post. Solution is to compose in a text or word editor such as Word, etc, then copy and paste into your post.
Ok I used my phone for this so I’ll type it out next time then post it. The evaporators where pretty clean before I flushed and cleaned them since they were the only thing I reused and everything else I replaced includes all lines , accumulator, ot,txv, condenser , ac compressor, high and low pressure switch
Excursion2001
Update
so I had to find a way to hold the gas pedal down I have electric seats so I grabbed a breaker bar and put it on the seat and moved the seat forward on the pedal . I got the engine up too 1800rpm and checked gauges . My gauge set on low side started to drop and my high side began to rise is this it’s operating pressure when it’s rpms are @1800??? If so my gauges where reading low side 3.2 bar( 46.4 psi) and high side 19 bar (275psi) with the temperature out side being 95 outside according to my temp gauge and my suction lines began to sweat
I am not a dual system guy but those readings seem good to me.....wait for John or Tim to weigh in
Are you able to get a temp (hopefully with a thermocouple) at the vents?
When on the road would you not be keeping your RPMs between about 1800 to 2500 ?
Have to wonder where you are that your native pressures are in bar
Excursion2001
tbirdtbird wrote: Wed Jun 23, 2021 9:41 pm I am not a dual system guy but those readings seem good to me.....wait for John or Tim to weigh in
Ok I shall wait ahah I haven’t got the chance to take it off base but I know going at around 35mph it will only get to 70ish degrees out of the vents if it’s cooler like this morning it will get colder like 60 out of the vents but no way if it’s 100+ outside it will only blow 70 and 1800 rpm my speed around 65mph . My gauge set only has bar so I iv got used to it
Are you actually measuring vent temp or estimating.....
I don't remember anymore, but did you check the fans? Are they going on and off? Also, did you charge it with both the front and rear A/C turned on?
Excursion2001
tbirdtbird wrote: Thu Jun 24, 2021 6:38 am Are you actually measuring vent temp or estimating.....
I have a temp gauge in the vent it’s just hard to read it cause it’s one of those small ones
Excursion2001
JohnHere wrote: Thu Jun 24, 2021 8:22 am I don't remember anymore, but did you check the fans? Are they going on and off? Also, did you charge it with both the front and rear A/C turned on?
By fans you mean the fan on the engine yes it’s pulling plenty of air as well as the cabin blower motors . And I did charge it with both front and rear on max settings the blend door is working and so is recirculate
