Tim,
Will evacuating the system also pull some of the original oil out, i.e. require adding additional oil??
Phil Swanson
Evacuating System Oil Content
Re: Evacuating System Oil Content
Last I knew it will pull a little bit out, prolly more as vapor, but not enough to worry about.
Agreed.tbirdtbird wrote: Tue Jun 22, 2021 8:13 am Last I knew it will pull a little bit out, prolly more as vapor, but not enough to worry about.
R & R machines have an oil seperator. Took many uses to fill the oil reserve.
