06 Jag schrader valve replacement
Re: 06 Jag schrader valve replacement
I agree about changing both Schrader valves. They're relatively cheap (compared to the same part from Jaguar), and you might as well do it while the system is empty of refrigerant. Don't forget that the caps do the actual sealing, so it's important to find the proper replacement parts for those as well.
