original transducer into a universal system
jwk87
Post by jwk87 »
Hi all,
first time poster on this forum have looked at a number of posts as a guest though.
I have done an engine conversion in my vehicle. I am not using the donor air/con or heater box but am using a universal heater/ac setup.
On the engine loom I have a wire for the original transducer. The transducer is connected to the top outlet going into the condenser (pic 3 and pic 4). I have spoken to the supplier of the universal aircon and he suggests that I use a universal pressure switch (pressure switch pic).
My question is how would I incorporate the original transducer from the donor car into the universal air con setup or should I just use the universal setup with the pressure switch. The reason I am asking as well is that the car wiring loom to enable me to run this engine conversion that was supplied by the wiring company states that I should use the original vehicle transducer.
Any help or thoughts on this would be appreciated.
Jason
pressure switch.jpg (7.86 KiB) Viewed 3893 times
Pic 4.JPG (191.13 KiB) Viewed 3893 times
Pic 3.JPG (233.01 KiB) Viewed 3893 times
Re: original transducer into a universal system
Why not use a binary switch that fits the port. Wiring is just a simple power in and out to the clutch. These switches are for cutting power. If pressure beconmes to low or high.
