Compressor oil
Compressor oil
CAN I MIX PAG 46 WITH PAG 100 ? ON 2004 SCION OEM COMPRESSOR IS USING PAG 46 AFTERMARKET COMPRESSOR IS ASKING TO USE PAG 100,
Re: Compressor oil
Never mix oils is my recommendation.
P:602-233-0090
P:602-233-0090
Re: Compressor oil
What Scion? The only ones from that year are Xa's and Xb's and their Denso 5SE09 compressors are rated for ND oil 8 (any DEC PAG 46 is the commercial equivalent).
Perhaps some compressor manufacturers/remanufacturers just won't bother about researching/listing the proper oil type and viscosity, and they just settle on a universal kind of recommendation, which once used to be PAG 100.
(In a similar fashion to some shops that just won't bother themselves with storing different AC oil type and viscosities, and only use PAG 100 or Ester 100 on every AC job, ranging from a simple recovery+vacuum+charge to a brand new compressor).
PAG 100 is really meant for some vane comps and some Sandens. Entirely out of place on swashplate applications.
Re: Compressor oil
Thank for helping me
Re: Compressor oil
THAT INFORMATION HELP I WAS CONFUSED
- THE INFORMATION HELP ME
- SWASHPLATE PAG 46.jpg (8.6 KiB) Viewed 648 times
- ROTERY VANE COMP PAG 100.jpg (30.65 KiB) Viewed 648 times
