The original TXV was replaced with a 4seasons TXV: https://www.rockauto.com/en/moreinfo.ph ... 7932&jsn=9. All components were 4seasons, except for the condenser which was a Denso part.
Think it's worth replacing the 4seasons TXV with an OEM one?
2007 Honda CRV Low Pressures
Re: 2007 Honda CRV Low Pressures
It's your call. I'm just letting you know that there's much more behind an automotive TXV than "Evaporator gets cold, TXV closes; evaporator gets warm, TXV opens".
Rockauto lists two different Denso valves (and matching Honda PNs) depending upon where the car has been assembled.
