Clutch wont enegage
Zimmsusie
Clutch wont enegage
Post by Zimmsusie »
Several years back a new compressor was put in and charged, but it never actually blew cold air. Now I'm on a mission to figure it out.
I have checked fuses, relay, relay wires, the plug at compressor. Added a half a can of diy freon and sprayed lines down with soapy water. When I hooked up the can it was already reading 80 psi. I am at a loss. I was just going to replace the compressor and clutch orfic tube and accumlator but I called a shop he said he doesnt think that issue but wont be able to look at the car for a while yet and doesnt know what it would cost to look at it until hes looked at it. :/
Any one have any ideas or know what's wrong?
1995 buick lesabre custom.
Re: Clutch wont enegage
You mentioned that you checked the connector at the compressor, but do you see voltage there with the system turned on?
