Hi guys, I am in the process of redoing the AC system on my 92 Buick Roadmaster. I pretty much bought everything I needed (new updated scroll compressor, accumulator, orifice tube, seals, etc.), but I didn't realize until after getting my stuff that there are different colored AC switches...for both the compressor mounted one and the one on the accumulator.
Since I am converting from R12 to R134a, I have no clue as to which colors I need. At the moment, the new ones I bought are a GPD 1711334 (blue) compressor switch, and a GPD 1711250 accumulator mounted clutch switch (white hex end, black plug end). The 1711250 says "R12" on it, so I assume it won't work with the 134a conversion.
The old switches are yellow on the accumulator and gray or white on the compressor.
Any help is appreciated!
1992 Buick Roadmaster, R12 to R134a
Re: 1992 Buick Roadmaster, R12 to R134a
So after a bit of research this morning, I discovered that the difference between all the compressor mounted switches mainly relies on where the keyed slot/tab is clocked on the switch/plug. Somehow I managed to order the correct switch for the compressor, but I am still not sure on the accumulator mounted one.
- Correct compressor switch
- IMG_20200328_125011fgfg.jpg (97.92 KiB) Viewed 5293 times
