Low Cooling AC
kapilamuni
Low Cooling AC
Post by kapilamuni »
Hi all,
Recently changed my car's AC compressor clutch bearing. All went week & afterwards cooling was perfect for only 3 days.
Now the cooling has reduced to a very low level.
Here are my observations;
Outside temp = 32 C
When idling @ 750 RPM low = 75 PSI HIGH = 170 PSI, Interior temp = 27 C
1500 RPM LOW = 55 HIGH = 180 Interior temp = 26 C
2000 rpm low = 45 high = 200 Int temp = 25.5 C
With a card board inserted in front of AC fans, to cover air flow
2000 RPM LOW = 45 HIGH = 210 Int temp 24 C
Your advise appreciated.
kapilamuni
Re: Low Cooling AC
Oops. Forgot add.
My car is BMW 525TDS with ND 10PA17 compressor.
Also, noted that with AC off, after about few minutes LOW = 120 PSI & HIGH = 120 PSI.
Re: Low Cooling AC
What year?
kapilamuni
Re: Low Cooling AC
It's 1996 june.
Re: Low Cooling AC
No listing in the US for that vehicle. If an expansion valve system. Your low side pressures are high.
kapilamuni
Re: Low Cooling AC
Yes, it's an expansion valve system. What could be the reason/s to have high low side / low high side pressures?
Re: Low Cooling AC
Is this an original R134a vehicle? Charge levels is a place to start. Possible restriction but unlucky. Normal expansion valve systems will have a low of around 12/18 at high RPM.
kapilamuni
Re: Low Cooling AC
Yes it's original system came with the car.
Can it be the clutch not engaging properly? Before this issue, on & off the belt slipping screeches were heard but not continuously. But cooling was not affected. Now it's not making such noises & the belt is fairly new.
The ratio you mention, is it low/high pressures or temp/pressure ratio?
Re: Low Cooling AC
On some AC clutches, the gap becomes too large and and will not engage; can be reduced by removing a thin shim.
kapilamuni
Re: Low Cooling AC
You are head-on.
Removed one of the shims and cooling back to normal.
Thanks.
