69 Camaro Back Again from 2007...
Supported By Hecat Inc.
Heat Exchanger Cleaning & Applied Technologies
Forum provided to discuss internal flushing procedures. A/C, Engine Cooling, Trans Oil Coolers, and More. Karl Matis will be your host in this forum.
jweb47
Post by jweb47 »
I had a post in 2007 http://www.autoacforum.com/messageview. ... adid=17957 and I'm repairing the system after an apparent compressor failure (stuck internal reed valve suspected) so I'm going to flush the system.
Since this is basically a hybrid system (everything OEM except compressor and condenser) and yes I did use the POA valve set for R134. For some reason I can't find my notes on the quantity of oil I used. Everything will be flushed except for the compressor and drier which of course are new. I plan to use 6 oz. (PAG 46) in the compressor, 3 oz. for the drier/lines but am uncertain about the rest. Can anyone help me on this one? Thanks
HECAT
Re: 69 Camaro Back Again from 2007...
Post by HECAT »
I do not have the oil quantity requirement for your system, but I would GUESS it needs about 6-8 ounces of oil. So you may be good with your 9 oz. plan.
Karl Matis
www.hecatinc.com
Please support this Forum
Buy your A/C products at www.ackits.com
jweb47
Post by jweb47 »
I'm about to go out to take it all apart and flush so maybe someone will have another recommendation later on before I seal everything. Thanks for your input though. (I seem to recall your user name from years ago)
HECAT
Post by HECAT »
Yup, been around so long, I thought the "grumpy old man" avatar fit.
Karl Matis
www.hecatinc.com
jasmyndube
Post by jasmyndube »
So you may be good with your 9 oz. plan. Phen375
HECAT
Post by HECAT »
If you have questions ask away, or maybe start a new topic.
Karl Matis
www.hecatinc.com
HECAT
Post by HECAT »
Welcome Big, thanks for your comments.
start new topic here............ Yes, if you would like to.
Nice Discussion Is Going on Here..... Not much to discuss, you are responding to a very old post.
Any One Can Start The New Topic..... Sure they can.
Karl Matis
www.hecatinc.com
