Contact cleaner for a DIY evaporator flush
Supported By Hecat Inc.
Heat Exchanger Cleaning & Applied Technologies
Forum provided to discuss internal flushing procedures. A/C, Engine Cooling, Trans Oil Coolers, and More. Karl Matis will be your host in this forum.
Moderators: bohica2xo, JohnHere, Tim, Dougflas
Re: Contact cleaner for a DIY evaporator flush
I know it has been a while and sure you have solved the problem. Very early on when flushing was being more of a concern. We used off the self isopropyl alcohol. It's not the best and has a flammability issue but it worked.
Better option and not a bad choice if you don't do a/c for a living.
https://www.ackits.com/flush-equipment- ... wgun-25615
https://www.ackits.com/flush-equipment- ... ased-17344
Note Supplies change brands on us at times. Keep that in mind with flush solvents.
