Page 1 of 3
Grayish Powder Inside High Pressure Line
Posted: Thu Jun 24, 2021 1:14 pm
by m240b
Greetings once again.
You guys helped me out back in 2019 repairing an A/C system on my family member's 2005 Honda Civic LX. I'm back looking for some help again this time on my 2004 Honda Civic LX. I had no cold air, connected my manifold gauge, the system was low on both sides when running. Added refrigerant but only the high side was increasing while the low side remained at around 40psig, still no cold air. The low side was low and the high side was high. The Internet told me these were the symptoms of a bad/clogged/stuck expansion valve. I opened the system and removed the evaporator and the expansion valve. I used a Q-tip and swabbed the inside of the high-pressure line. The Q-tip came out gray and green. I know the green is from the leak detection dye but I remember you guys telling me that the gray was a sign of the seals on the compressor going bad. Should I just replace the expansion valve? If so, would the system just fail again in the near future? What would you guys suggest?
Attached is a picture of the Q-tip.
Re: Grayish Powder Inside High Pressure Line
Posted: Thu Jun 24, 2021 3:18 pm
If the photo is a true representation of the system. It looks like normal wear.
Posted: Thu Jun 24, 2021 3:48 pm
by m240b
So would you recommend just replacing the expansion valve?
Posted: Thu Jun 24, 2021 3:52 pm
by m240b
Also how long can the system be open before the receiver drier goes bad? I have it open right now while I try and figure out what to do.
Posted: Thu Jun 24, 2021 4:25 pm
m240b wrote: Thu Jun 24, 2021 3:48 pm So would you recommend just replacing the expansion valve?
That's going to be your judgment call. No way for me to tell from a picture of a q-tip.
As far as being open, from the professional repair view. Not more than a few hours.
Posted: Thu Jun 24, 2021 4:52 pm
by m240b
So I decided to roll the dice and just replace the expansion valve. Pulling a vacuum right now.
Posted: Fri Jun 25, 2021 7:40 am
m240b wrote: Thu Jun 24, 2021 4:52 pm So I decided to roll the dice and just replace the expansion valve. Pulling a vacuum right now.
Hopefully, you added a little oil back to the system.
Posted: Sat Jun 26, 2021 9:01 am
by m240b
Thanks for the replies everyone. I pulled a vacuum and closed the system but I did not charge it because I ran out of time and had other things to do. The replacement TXV that I purchased is aftermarket. I was not aware that they are bad quality. I have the original TXV in a ziplock bag. Can the original be cleaned/refurbished and reused by the user or is that something that only the pros can do? I need to get some DEC PAG and add it to the system though I am not sure how much I should add. I bought some from Amazon back on 2019 but now I cannot find any. I need to find an Auto AC place over here in Houston because all I see at the autoparts stores is regular PAG-46. I should probably flush the system but I don't have access to shop air, all I have is pancake compressor which runs out pretty quick.
Posted: Sat Jun 26, 2021 11:25 am
Did you look at other places besides Amazon for the DEC PAG 46?
Posted: Sat Jun 26, 2021 1:49 pm
by m240b
Checked again and found some on Amazon but I think I will check with local shops first before I place the order. Hopefully, they don't give me the deer in the headlights look when I ask for double end-capped pag 46.
