Depressurising a/c - no high pressure side valve?
snwslth
Postby snwslth » Fri Jan 08, 2021 6:32 pm
Hi
There is a pressure switch in the valve location, wondering if this is mounted on the valve? If not what is the procedure for depressurising?
For photos see - https://www.jaguarforums.com/forum/xj6- ... -a-241319/
Greg
Re: Depressurising a/c - no high pressure side valve?
Postby JohnHere » Sat Jan 09, 2021 8:09 am
It looks to me as if this is an R-12 car and that someone attached an aftermarket high-pressure cutoff to the high-side Schrader valve port for reasons not known. There's no way to know whether there's still a Schrader valve below the HPCO, so I wouldn't take the chance of just removing it. You could recover the charge through the low side only, although doing so will be a slower process.
I can't identify the cylindrical shaped part.
Postby Cusser » Sun Jan 10, 2021 7:39 am
JohnHere wrote:You could recover the charge through the low side only
This
snwslth
Postby snwslth » Tue Jan 12, 2021 6:27 pm
Thanks, the engine must be running to discharge from low side only?
Postby JohnHere » Tue Jan 12, 2021 10:37 pm
snwslth wrote:Thanks, the engine must be running to discharge from low side only?
It's not necessary to run the engine to recover the charge, but doing so beforehand will warm everything up and help the recovery process go a little faster. The refrigerant and usually some oil will come out assuming that the system still has refrigerant in it.
Return to “Automotive Air Conditioning Procedures, Tips and FAQ.”
