Using Shop Air To Leak Test?
Posted: Sun Nov 15, 2020 4:53 pm
by seagiant
Hi,
I see guys on U-Tube, using shop air and a soap bottle to find leaks in Auto AC Units.
Thoughts?
Re: Using Shop Air To Leak Test?
Posted: Sun Nov 15, 2020 6:21 pm
Nitrogen is a better gas for leak testing. Shop air unless used with a paint regulator will induce moisture to the system.
Posted: Sun Nov 15, 2020 7:00 pm
by seagiant
Hi,
Thanks, but won't the pump down get rid of air anyway?
That seems to be the thinking on it, but I do understand Nitrogen is a better mouse trap!
Posted: Sun Nov 15, 2020 7:45 pm
Air yes, moisture depends!!
Posted: Mon Nov 16, 2020 11:42 am
by seagiant
Hi,
Thanks!
Posted: Wed Dec 02, 2020 11:24 pm
by swampy 6x6
HHi
Shop air contains alot ,,a huge amount of moisture. Shop air condensate trap is only very basic a moisture trap such as used for spray painting worth 100-1000 dollars traps moisture. Besides moisture will be trapped in refrigeration system easily as a result just donot introduce potential problems to begin with .
Always taught only use nitrogen . Besides nitrogen can go 200psi which is where u want to test . Shopair will only go 90psi
