Hi,
I see guys on U-Tube, using shop air and a soap bottle to find leaks in Auto AC Units.
Thoughts?
Using Shop Air To Leak Test?
Re: Using Shop Air To Leak Test?
Nitrogen is a better gas for leak testing. Shop air unless used with a paint regulator will induce moisture to the system.
P:602-233-0090
P:602-233-0090
Hi,
Thanks, but won't the pump down get rid of air anyway?
That seems to be the thinking on it, but I do understand Nitrogen is a better mouse trap!
Air yes, moisture depends!!
P:602-233-0090
P:602-233-0090
Hi,
Thanks!
Thanks!
HHi
Shop air contains alot ,,a huge amount of moisture. Shop air condensate trap is only very basic a moisture trap such as used for spray painting worth 100-1000 dollars traps moisture. Besides moisture will be trapped in refrigeration system easily as a result just donot introduce potential problems to begin with .
Always taught only use nitrogen . Besides nitrogen can go 200psi which is where u want to test . Shopair will only go 90psi
Return to “Automotive Air Conditioning Procedures, Tips and FAQ.”
