2004 jeep grand cherokee expansive valve replacement procedures
dieseldaisy
Postby dieseldaisy » Tue Jul 12, 2016 3:59 pm
Hi I am looking for help with learning how to properly and safely pull and replace and recharge my expansion valve in my 2004 jeep grand Cherokee 6 cyl 4.0 l
I am seeing the low side pressures holding steady at 5 psi and the high side holding at 225 psi?? expansion valve is the cheapest thing to start with right? I really could use step by step instructions on how to do this. do I need to evacuate? how does a diy do that all I see in the parts stores are vac systems but my understanding is that these are to only remove moisture after the repair and just before recharging?????????? Help!!!!!!
Re: 2004 jeep grand cherokee expansive valve replacement procedures
Postby Tim » Wed Jul 13, 2016 8:38 am
Get an All Data Subscription for you vehicle.
http://www.alldata.com/
System will need to be pulled into a vacuum before charging.
P:602-233-0090
Return to “Automotive Air Conditioning Procedures, Tips and FAQ.”
