Pressure switches
ajb
Pressure switches
Postby ajb » Fri Dec 28, 2018 6:05 am
Hello i am new to this site and retrofitting an ac system to an old vehicle.
it is using a gm style orifice tube with the big aluminium accumulator. i am wondering if it is possible to mount a trinary switch on the accumulator in place of the low pressure switch or if i require to insert a fitting that has the provision for a high pressure switch in the high side line.
i hope that someone out there can assist this amateur haha . thank you very much cheers.
vintage air tech
Re: Pressure switches
Postby vintage air tech » Mon Jan 14, 2019 1:36 pm
Since Trinary safety switches monitor the high pressure branch, using it in the low pressure branch would be useless. The cut on/off presets for the safety switch would not apply to the low side pressure to protect the system from a potential problem. I would find a beadlock fitting that has the safety switch port for the high side.
