Ambient temp around 75, suction pressure cycling with the compressor was going between 20ish and 50ish and on the high side between 100 and 110. A pressure chart from acprocold.com had that as low for both sides and to add refrigerant. I added 12 oz and a little more from a second can and the pressure came up and the compressor stopped cycling. The air was colder than before but not real cold. I took the truck for a drive and when I got back and the put the gauges back on then the pressure was on the suction side was 35 and the high side had gone to 325. After idling for a minute the compressor then started to go back to turning on and off this time with the pressure on the suction side 25-62 (the compressor would turn on around 62 and then cut off at 25) and the high side was going back and forth between 130 and 150.
That is when I found this forum and this post https://www.autoacforum.com/viewtopic.php?f=3&t=182&p=1024&hilit=f250#p1024. After reading that I went back and started the truck back up and started doing the cycling of the compressor and then the high pressure started to climb along with the low side. The high side reached 325 and the low side around 30. I sprayed some water on the condenser and the high pressure came right down and the compressor started cycling again and then after a couple of minutes the pressure would slowly rise again but it never got back over the 300 on the gauge. One thing I found was some cold air coming out of the where two the lines run into a box or plenum (see the pic below). So perhaps there is a leak somewhere with the air duct.
It seemed maybe two issues were happening a) it was low on refrigerant and 2) perhaps the condenser was not 100% or the orifice tube need be replaced. I was just about to add just a little more refrigerant when I notice the low side over 100 and the compressor no longer coming on.
Update: After sitting for about 45 minutes the compressor has started working again.
