2005 Toyota Prius high pressure low side
Neb623
Postby Neb623 » Sun Sep 30, 2018 4:54 am
Hi I just recently replaced the condenser, compressor, the suction line and discharge line on a Toyota Prius. Everything was new except the compressor. Currently the pressures are reading 60 on the low side and 120 on the high side. Air is blowing cold but the compressor is continuously on. I’m trying to figure out what I did wrong or if the compressor itself is bad. I should note that I forgot to add the 40 ml of oil to the condenser before installing it and instead added it with a syringe into the intake side of the condenser. Could this have caused the problem? Thanks.
Re: 2005 Toyota Prius high pressure low side
Postby bohica2xo » Sun Sep 30, 2018 9:18 am
Why were the listed parts replaced?
Was the system flushed?
What sort of equipment was used to evacuate the system?
How as the charge level determined? A scale & tank or cans and a guess?
What was the ambient temperature when those readings were taken?
Neb623
Postby Neb623 » Sun Sep 30, 2018 9:35 am
System lost pressure secondary to a slow leak for which I couldn’t determine the source with a sniffer or uv dye.
No.
System had zero pressure when I started working on it. I pulled a vacuum on it after replacing the parts.
I measured can weight pre and post charge to get the correct 16oz in.
77 degrees Fahrenheit.
Postby bohica2xo » Mon Oct 01, 2018 4:32 pm
The pressures look undercharged.
Given that the compressor is a reman, it could be a bad compressor if the charge level is correct.
I would add an ounce & see what it does. At 77f ambient I would expect high side pressures around 170 psi. Even if the TXV is stuck wide open it should cool better than that.
