Toyota Sequoia poor AC performance
Posted: Wed Sep 05, 2018 10:29 pm
by theherbster
Hi guys,
Wondering if you could help me out please. Dual Ac Sequoia doesn't seem to cool very well - poor performance in hot weather. Compressor seems to run constantly, but that may be the high temps here in Texas?
When I had the timing belt done, the garage noticed the poor performance, 'checked' the systems and told me my compressor was 'on it's way out' and wanted $2700 to change the whole system. Needless to say I told them to stick to cars as their comedy act was terrible.
I had the system evac'd and put in 39 oz exactly, to make sure it wasn't the levels, but not a real improvement.
Pressures are: LOW 55 HIGH 260
Temp 86 degrees
Humidity was 68% at the time
Vacuum 45 mins, check no leaks for 20 mins
The car had been running at 1500 rpm for a couple of minutes. What do you think could be the problem? Thanks
Re: Toyota Sequoia poor AC performance
Posted: Fri Sep 07, 2018 10:06 am
Condensing problem. Condenser fans , air path blocked etc.
Were those pressures taken at 1500 rpm? Both cabin fans on highest speed? Doors open?
What year is this Toyota?
Posted: Fri Sep 07, 2018 11:34 am
Also check to make sure no heated air or outside air is getting mixed in.
Posted: Sat Sep 08, 2018 6:16 am
by theherbster
2003 Toyota. Pressures at idle
Condenser fan kicks on fine with good airflow
Fans high speed with doors open
Hot goes hot and switches back to cold when I turn the temp.
Thanks for the replies so far.
Posted: Sat Sep 08, 2018 6:22 am
Post pressures at 1500 - 2000 rpm.
Posted: Wed Sep 12, 2018 10:59 am
I don't think it's the compressor, which seems to be putting out sufficient pressure. In fact, both high-side and low-side pressures are elevated. The pressure on the low side, 55 PSI, corresponds to evaporator temps in the high 50's. So I can see why you aren't getting enough cooling.
In addition to the suggestions already mentioned, it could also be a partially stuck-open TXV.
What vent temps are you seeing?
