R4 questions
Posted: Fri Jul 27, 2018 3:26 pm
by kenimpzoom
First off the car...its a 65 Studebaker, but someone graphted on a G-Body front end and so the AC system is non stock. I made none of these mods, but i have worked on cars forever so I know what I am doing around stuff, not so much on AC units. :D
It has an underdash ac unit which uses an expansion valve and R4 compressor. When I got the car it was 100% empty of freon. I flushed it good, changed the dryer and charged it up with R134. Worked pretty good. Then it leaked out. Then I charged it, then I found the leak on the back of the compressor.
So here is the problem..the old compressor manifold bolt hole stripped out and wont hold. That was fun when I tried to tighten it and it blew! So I need a new compressor. Old compressor was PN 1134354
Problem is, which new one will work and what gaskets to use on the manifold.
My orginal compressor has a small clutch and stepped manifold holes.
I got a 4 seasons PN 57231 which has the larger clutch with small bolts on the perimiter and the flat manifold holes with o-rings. I tried to match up differnt compressors, but they all looked like this one. Did they all convert to flat manifold and large clutch?
First, will my manifold work with this new style compressor, and second, what difference does the clutch make? Third, which o-rings/gaskets do I use if I can use this one.
Thanks, Ken
Re: R4 questions
Posted: Fri Jul 27, 2018 3:27 pm
by kenimpzoom
My current hose manifold.
Re: R4 questions
Posted: Fri Jul 27, 2018 3:30 pm
by kenimpzoom
This is what the new unit looks like
Re: R4 questions
Posted: Fri Jul 27, 2018 3:38 pm
by kenimpzoom
Found this, but I want more opinions. http://www.4s.com/media/4913612/-AB319- ... ashers.pdf
Re: R4 questions
Posted: Sat Jul 28, 2018 2:27 pm
by 71403
Flat hose block with non-stepped o-ring compressor is ok as-is. Are you saying it had a stepped port compressor with that flat hose block? That would require "pilots" or stack of washers neither of which I like to do.
Tho I'd be more concerned about kink on the discharge line.....
Re: R4 questions
Posted: Sun Jul 29, 2018 11:58 am
by kenimpzoom
Thanks.
The new compressor didn't quite bolt up right so I got the old compressor working.
I used a stud with proper metric threads and JB WELDed it into the compressor manifold and torqued up the manifold and it holds good now.
I will upgrade to a Sanden compressor this winter.
Ken
