High pressure service valve
Hi all. I have a 1993 s-10 that I am replacing all a/c components & will be converting to 134. On the high pressure line I would like to replace the service valve as it appears the valve inside can't be replaced. It looks like ac delco 15-5438 could work. Does anyone know if this one will work I would also replace with new r-12 style if new. Or would a 134 adaptor have a schrader valve inside so I wouldn't have to worry about this one leaking ? Thanks in advance to any help on this https://autoacforum.com/download/file.p ... iew&id=174
- 065-15-5438.jpg (13.61 KiB) Viewed 6773 times
- IMG_0838.JPG (52.09 KiB) Viewed 6773 times
- IMG_0841.JPG (23.43 KiB) Viewed 6773 times
