Pressure Relief Valve?
SlickGA
Postby SlickGA » Sun May 20, 2018 4:29 pm
Trying to replace the pressure relief valve on a 2015 Tahoe's compressor. The OE valve seems to be aluminum, but the only after-market varieties I can find are brass. The after-market ones also seem to have a longer threaded shaft part than the OE, and slightly different tapering before the hex nut. They aren't "vehicle specific" -- and even have nested bolt adapters to allow for different applications. Needless to say, I cannot get the after-market valve to properly seat and squish the o-ring to seal against the compressor -- it bottoms out against the compressor (metal on metal) before adequately squishing the o-ring.
Are the aluminum OE variety only available on new compressors?
Are these valves at all re-useable (or are they toast after blowing once?)
The issues leading to the blow-out of the valve have been solved, and the system works great otherwise, but until I find a way to consistently plug this hole in the side of the compressor with something that won't leak, I'm only good for a few hours.
thanks
Re: Pressure Relief Valve?
Postby bohica2xo » Mon May 21, 2018 4:13 am
In theory, the HPRV should re-seat after opening. Sometimes they do not.
If you have a valve that fits, but the threaded portion is bottoming out before the O ring seals you can probably trim the threads to the length of the part it is replacing.
The site sponsor should have the right one available. http://www.ackits.com/ 602-233-0090
Posting pics of what valve you have is a good idea too
