A6 compressor oil port
tomctomc
Postby tomctomc » Sun Aug 13, 2017 1:49 am
Quick question (tried to search but the terms were too common): does opening the oil fill port on a GM A6 compressor vent the refrigerant or can the oil level be checked on a pressurized system?
thank you
Re: A6 compressor oil port
Postby Dougflas » Sun Aug 13, 2017 3:23 am
Refrigerant will be expelled and oil if opened under pressure. You will have to recover the refrigerant.
tomctomc
Postby tomctomc » Sun Aug 13, 2017 3:51 am
thanks for the clear/concise answer!
