Retro Kit Valve
robmaxfli
Retro Kit Valve
Postby robmaxfli » Tue Aug 01, 2017 7:16 pm
I installed the retro kit screw on my low and high valves to my old R12 system - even though I am keeping the car an R12 car. The reason I have them installed is so my loaner gauges will work (r134 fittings).
Question for the Low side valve: Can I leave my lower/original Schrader valve installed and then install the retro valve on top of it? (or do I have to remove the original Schrader valve prior to installing the new valve on top?)
thanks!
Re: Retro Kit Valve
Postby Cusser » Tue Aug 01, 2017 7:22 pm
robmaxfli wrote:I installed the retro kit screw on my low and high valves to my old R12 system - even though I am keeping the car an R12 car. The reason I have them installed is so my loaner gauges will work (r134 fittings).
I would suggest to buy adapter hoses/fittings so the R134a service gauge hoses will fit on the R-12 service valves.
Re: Retro Kit Valve
Postby Cusser » Wed Aug 02, 2017 6:59 am
I changed my mind: just buy a complete R-12 service gauge kit from an Ebay supplier, under $25 shipped.
