Mitsubishi Marige AC hose hard vibration when first turned on
bdollar
Postby bdollar » Tue May 23, 2017 6:46 pm
A few months ago I had the compressor replaced and this has be happening ever since (see video of vibration here: https://youtu.be/CyejzWj8lYk). It only happens if the car sits for a couple of days and then I turn the AC on. At the moment I turn it on this vibration happens. I showed it to the guy at the shop and he says the video does not help. I need to leave it for two days so they can connect instruments and get readings to help them figure out what is going on. He said the hose was not replaced and maybe the pressure from the new compressor is causing the old hose to vibrate.
