Underwhelming cooling performance after complete A/C restoration
swampy 6x6
Re: Underwhelming cooling performance after complete A/C restoration
Post by swampy 6x6 »
hi
sight glass full
suction line very cold
approx expected weight charge
approx pressures 35/200
assuming condensor and evap clean
good to great airflow over condensor
fast idle 1500rpm yes
bypass heater core/tap ie block water flow
controls set to recirculate NOT FRESH
system flushed and reoiled with correct type and quantity of oil
The last meaningful post in this thread was in July. Do you think we are not following the replies? You are either a spammer or an HVAC guy trying to look smart in MVAC
Suggest finding some other forum to post on and become famous
