Need a/c clutch coil removal help!
brucemc777
Post by brucemc777 »
Please forgive my double post, i am not getting any response from the Jeep forum i posted in.
Working on my daughter's (OK, i admit it, i paid for it) 2006 Jeep Liberty.
All the diy videos claim there is a second snap ring holding the coil in. Not on this one, or at least, not that i see.
The interior cavity surrounded by the coil after removing the clutch/pulley looks very different than those in the videos that usually have a fairly flat backing.
No snap rings that i understand, but the internal hub almost looks like some sort of socket might be used to remove it, or a small hole that can be seen in the second picture at about the 5:30 position (where the video second snap ring usually is) might be the answer.
Does anyone out there KNOW how to handle this?
Thank-You so very much for helping me!!!
AC Coil Removal 02.jpg (73.83 KiB) Viewed 5146 times
AC Coil Removal 01.jpg (79.83 KiB) Viewed 5146 times
GM Tech
Re: Need a/c clutch coil removal help!
Post by GM Tech »
If there is no snap ring, then your coil is pressed fit onto the aluminum snout. Use two screwdrivers to pry it off with a rocking back and forth motion. To re-install use an arbor press, or tap it into place with a ball-peen hammer and punch.
brucemc777
Many, many, thanks! Looking forward to attacking it-
brucemc777
@ GMTECH - Thank-you very much, and i should of said so some time ago. All is working well now. I used a hammer and block of wood to firmly seat the coil.
I find it very weird that not one of the many resources i read & watched showed this to be a possibility - they all showed a second snap-ring.
As to the other forum i posted to, one specifically for Jeeps, still not one answer...
