Compressor oil
Moderators: bohica2xo, Tim, Dougflas, JohnHere
Daniel
Compressor oil
Post by Daniel »
CAN I MIX PAG 46 WITH PAG 100 ? ON 2004 SCION OEM COMPRESSOR IS USING PAG 46 AFTERMARKET COMPRESSOR IS ASKING TO USE PAG 100,
Re: Compressor oil
Never mix oils is my recommendation.
Al9
Re: Compressor oil
Post by Al9 »
What Scion? The only ones from that year are Xa's and Xb's and their Denso 5SE09 compressors are rated for ND oil 8 (any DEC PAG 46 is the commercial equivalent).
Perhaps some compressor manufacturers/remanufacturers just won't bother about researching/listing the proper oil type and viscosity, and they just settle on a universal kind of recommendation, which once used to be PAG 100.
(In a similar fashion to some shops that just won't bother themselves with storing different AC oil type and viscosities, and only use PAG 100 or Ester 100 on every AC job, ranging from a simple recovery+vacuum+charge to a brand new compressor).
PAG 100 is really meant for some vane comps and some Sandens. Entirely out of place on swashplate applications.
Daniel
Re: Compressor oil
Post by Daniel »
Thank for helping me
Daniel
Re: Compressor oil
Post by Daniel »
THAT INFORMATION HELP I WAS CONFUSED
THE INFORMATION HELP ME
SWASHPLATE PAG 46.jpg (8.6 KiB) Viewed 1541 times
ROTERY VANE COMP PAG 100.jpg (30.65 KiB) Viewed 1541 times
