Re: crazy high high side pressure, just right low side pressure
Posted: Mon Sep 28, 2020 2:24 pm
by Dougflas
Spray a water hose on the condenser when the pressures are high. Does it drop like a rock?
Posted: Mon Sep 28, 2020 3:34 pm
by Dougflas
You need to be careful with aftermarket fans. Some of them allow you to wire them in reverse rotation. Some of them mount with different types of mounting that will allow them to rub on the condenser and radiator. Some of them do not have the proper CFM ratings. SDometimes you are better off biting the bullet and getting the OEM fans.
Posted: Tue Sep 29, 2020 7:03 am
Al9 wrote:Don't know why all OP posts disappeared at once,
Might be from the recent attempt to update the forum software. IT got an error so reverted back.
