Grand marquis a/c problem
Posted: Sat Sep 05, 2020 7:08 pm
by larrys2006
I have a 2004 grand marquis 60k I have a freon leak the system was empty I hooked up the gauges and put 90 psi in the system yes it was air and no I did not have nitrogen but I thought the system had air in it all ready so what the hell 0 psi. I started the car and turned on the a/c for 3 seconds just to see the gauges move I could not read the numbers that fast and the high went up slightly but the low gauge peged high. it has a new orifice tube and accumulator before I knew their was a leak is it the compressor and can I rebuild it what rebuild kit do you recommend I do not trust buying rebuilt units you never know what you are getting.
Re: Grand marquis a/c problem
Posted: Sun Sep 06, 2020 8:21 am
Compressing air is not going to provide any reasonable diagnostic results.
Go with a new model much better option.
https://ackits.net/product/14-0090new/
Posted: Sun Sep 06, 2020 10:21 am
by larrys2006
I am on $780 social security a month so is their a rebuild kit? is it the plates?
