Ac cold at idle, gets warm
Stick-man
Postby Stick-man » Sun Aug 09, 2020 6:52 pm
Hello, I have searched you tube and posts here with no luck. I have a 2001 Ford F-250, when I start it up after work and sit there for 15 minutes +/-, it is ice cold (40*F) and frosts up the windows. Then when I start driving it will go to around 60*F sometimes even 70*F. Usually if I am stopped it gets cold again. Any ideas as to what the problem could be. Most issues I find after searching is warm at idle. Thank you.
Dougflas
Re: Ac cold at idle, gets warm
Postby Dougflas » Mon Aug 10, 2020 6:18 am
Did you recover and recharge to factory specs? Sounds like a refrigerant charge problem.
Al9
Postby Al9 » Mon Aug 10, 2020 2:06 pm
Maybe the evap is freezing up once compressor capacity climbs up enough? Does the air flow suddenly and eventually reduce?
Dougflas
Postby Dougflas » Mon Aug 10, 2020 4:16 pm
Fords had that problem of either low charge or bad cycling switches. What happens (low charge) is the refrigerant system will quick cycle when going down the highway. At idle the temps will be fine. The first thing to do when you have most AC problems is to verify the correct charge.. and thus eliminate that as a problem. Fords also had cycling switch problem back then also. (#2 thing to check)
Postby Tim » Mon Aug 10, 2020 4:17 pm
What are you pressure readings at arounbd 1500 rpm?
P:602-233-0090
Al9
Postby Al9 » Tue Aug 11, 2020 3:33 am
Dougflas wrote:The first thing to do when you have most AC problems is to verify the correct charge.. and thus eliminate that as a problem.
Gospel truth.
Unfortunately enough, too many owners feel too cheap (or lack the money needed for proper car maintenance in general) to either get the equipment needed (and then this is also illegal in many countries, such as the whole EU) or pay a pro to do it the right way (and too many shops unfortunately won't like this kind of do-it-right customer attitude) - that is, weighing the charge left in the system.
